showcrop
I am restoring a 1967 car. It had some sort of asphalt material stuck to the floors that was very brittle, cracked, and coming off so I have removed it all. I want to replace it plus add significantly more. They make some pretty good stuff for this, though most is foam based. I want something with some weight to it that will stick like glue. I thought of ice and water shield, put down in two layers. My only concern is how it will act when it is hot. I can't imagine that the inside of the car will get anywhere near as hot as a roof in the summer, but on the other hand the Ice and water shield is held down with a lot of nails.
