What electrical and other components on the block and dash do I mask and how is the best way to do so such as spark plugs and similar items. thanks
Ford, and I expect pretty much all the others added the electrical components except for starter and generator after painting the chassis. If the starter was added after painting the tractor would not start. So mask everything else. Most of us remove most of the electrical before painting.
It's best to take as much off the tractor as you can before painting but if you don't want to go there shrink wrap does pretty good covering up wiring.
Does anyone have pictures of a masked engine area showing what was masked and what was removed? Mine is a Ford 8N and a Jubilee. thanks
much.
