Hello, I have a question for those of you who have found an answer to this question by past experience. My knowledgeable PPG paint guy has retired and so I'm needing you guys' help. I use the PPG Omni paint line and was thinking of using Single stage urethane for the frame and then using Basecoat/clearcoat for the sheetmetal. If I'm using the exact same paint number, with the exact same PPG Omni products except for one is single stage and the other is basecoat/clearcoat, should the end result be the same shade of color when put next to one another? Just maybe one a little shinier than the other? Normally I use single stage on everything but would like to try Basecoat/clearcoat on the sheetmetal if possible to be done without being a problem when it comes to matching the shades. Thanks in Advance!
