high build primer over epoxy primer?
SDE
I would like to know if I can paint a tractor grill with epoxy primer and then put high build primer over that to fill in any left over rust pitting holes?
Yes I did treat the rust with a rust converter first.
Thank you
SDE
I have put some putty on it. I thought I could get the primer to fill the rest.
Thank you
sde
yes, but a little bondo or spot putty first might save you a few coats and some frustration. The high build surfacer can only do so much in one or two coats -
i use a clean shop towel under my hand and rub all over ,it helps find all the low and high spots.or run water over it so the dents show up easire .
rick
