Someone cut the opening of the hood all the way to the edge of my F-20 hood. This way the hood could be removed without removing the steering shaft and having to lift it up over the exhaust pipe. I welded it shut, and I am quite sure that I will need to enlarge n the hole. Any ideas on how to adjust the opening? I have a burr bit and an angle grinder. I don't know of a better way to cut a curved uneven surface, without damaging the hood. The opening is in a section of the hood that transitions from the narrow to the wide end. I have a sawsall and a jig saw also, but I don't think I can cut a nicely shaped hole with them. Ideas anyone???
Thank you
SDE
Thank you
SDE
