Parts for an old spray gun?
PJH
I have an old spray gun and I noticed that I've lost a part from it. It's a copy of the Binks #7 that was sold in the auto parts stores in the seventies for $35. I think Binks parts fit it, but I've never had need to find out, until now. The part I lost is the knurled packing nut that goes around the short shaft that the trigger depresses. I guess this thing came loose some time and slipped off of the shaft to who knows where. Is there a parts supplier that would have this part? Or should I go looking for something more modern? I've looked at the cheapo HVLP guns in the farm stores, but hang them back up because I know nothing about them. Implement painting is all I use it for.
Thanks for any advice.
Can't help with parts, but if it is truly a knock off, then get a manual online and find a part number. Google it and pick it up.
Now I had a binks rep in at work last week, they have a fairly new gun that has a Teflon coating on the outside and inside. They say it is really easy to clean. Might be worth looking at something a little more modern. I know I am going to look at it. It is $400+, but good stuff costs money.
It's possible I have the part you need. I have one the threaded part is 17/32" Od and 7/16" long. As best as I can tell it's 28 threads per inch. It has 7 threads in 1/4". From the treaded part it is 15/32" in diameter and 19/32 long. The diameter hole in the end for the fluid control pin is 7/32".
Astro is correct! This one says Astro AS-7 on the handle. I think that I bought it at the local NAPA store. It seemed to work good, but I've never had another to compare it to. I had a friend who was a bodyman, and he recommended it.
Stephen, this part is tiny - it is not the packing nut that the long needle goes through - it is for the short rod that stubs out against the trigger. I have everything but the knurled female threaded nut. The exposed male portion has three threads visible. I couldn't find a parts diagram for a Binks #7, but item #24 in the link resembles my missing part.
Similar part
I have that part too. The threaded cap looks like it fits over 11/32" shaft.
That looks like it Stephen. Is that part for sale? I can't figure out how to enable my e-mail.
You just click the "Email Notification" right above Preview Your Reply to receive email notification.
Just email me your mailing address and you can reimburse me the postage. These are just old guns I should throw away. I don't repair sprayers anymore. If cleaning doesn't fix it, I buy a new gun.
