applying decals
rkc9700
I ordered some decals for my TW10. I guess they are the paper backed , vinyl ones . how or what is the best way to apply them? are they the get it right the first time, kind? any hints or help is really appreciated.
Generally you apply masking tape the 'top' edge of the decal leaving the paper backing on it for the time being. Then locate the decal where you would like it to be affixed and press the tape to the panel. Mix up a pint of water in a spray bottle and add a couple of drops of dish soap mixing thoroughly. Lift up the taped in place decal and spray the soap mixture over the area where the decal will be applied and remove the paper backing. Do NOT press down on the decal rather take a small rubber squeege and starting from the top edge, work the soap mixture out from under the decal-being careful to remove any air bubbles as you work towards the bottom. Any remaining bubbles can be removed by poking them with a pin or the corner of a razor blade and re-application of the squeege.
Are they vinyl or Mylar? Mylar has clear between the letters or if they are small printed decals. If there Mylar, get sticker wet, get fingers wet (water should have a drop or two of dish soap), Perl back and apply. Often helps to have masking tape on tractor as a guide. Once everything wet, apply decals and squeegee out water. Once dry, rub finger on outside edge of decals to get any adhesive residue off.
If vinyl, there will be 2 papers (front and bank of decals). Put a piece of masking tape (I prefer painter tape) along top edge to act like hinge. Once you get it on where you want it, flip up and peel back off. Carefully lay down and rub out really well. Slowly peel face sheet off and presto you are done.
