Which HVLP gun to buy...
Seth_ia
I'm shopping for a new HVLP gun for single stage paint. I'll admit I'm late to the HVLP party. Currently I'm still using my trusty Binks model 7 gun. As such I'm not up on what the best HVLP guns currently are.
Does anyone want to help me spend some money and recommend a good gun that you like?
I am not a paint guy, but since you haven't gotten an answer, I will just pass on that when that question comes up, which it does frequently, a lot of guys will answer that the harbor freight guns work very well for the money.
I think when you get a HVLP sprayer you will shelve it and go back to your Binks 7. The Binks will do a far better job easier. The HVLP is designed for the environmentalist to put less paint in the air. It's not designed for doing a better job of painting or making the job easier for the painter.
I have used a Binks # 7 for over 25 years. I have tried 3 different cheaper HVLP guns none did as good a job as the Binks. I recently bought a DeVilbiss FLG-4 from T.P. tools with 3 tips and a air adjusting valve for $185. I have used it for primer and a few small jobs with good results I think there is a learning curve with these guns. Once I master this I think I may get the Binks M1-G HVLP. I doubt that any will do a better job than the Binks #7.
we use sata and anest iwata spray guns here at the body shop. sata is the cadillac, but the iwata is a very close second. a good gun is going to set you back anywhere from 400 to 900 dollars depending on the bells and whistles you want. the hvlp guns have a learning curve, but once you get used to them, they are the berries. they will use about 40 percent less paint than a siphon gun from less overspray. you will notice a considerable savings in material. also, additional tips and over haul kits are readily available. also, the guns are a lot easier to clean than a siphon gun.
Do you use any kind of disposable cup system with the guns you mentioned? I Sata has a pretty slick looking system.
seth, we use the 3M FPS system. nice system, and it allows storage of extra base coat if you mix too much, and can be used on a different vehicle with the same paint code. saves solvent on the gun cleaning unit too with no cups to clean, just the gun body.
The Astro EVO-T series gun (4014) is a fairly nice Iwata LPH400-LV knock off. Not much of an air hog as far as HVLP's are concerned either.
I have the LPH400-LV and used to use the EVO4014.
I've tried the H.F. #47016 and I can personally attest to the fact it's a piece of junk. I would think their other lines such as the 'professional series' wouldn't be something I'd rate right up there either. Can they be made to apply paint somewhat properly?, in the right hands I'm certain they could.
This $150.00 weapon has been a good one.
Has a little larger needle in it for
thicker stuff, unlike my $400.00 one that
is only good with thinner paint.
Painting equipment is like many other things,the gun is only good as the painter behind it. If you are willing to pratice and plan doing automotive quility level painting,invest $300 or more in any name brand,otherwise a cheap gun will get you by. With so many paints containing "glitter"these days you will need one of those like glennster mentioned and a lot of pratice. Now there's an interesting thought,a tractor which changes color as light angle changes.
