I have a 1947 International KB1 truck I am restoring. I repaired the rotted out metal on the box by patching in new steel. I thought I had taken care of all the rust issues and took the box to be sand blasted and epoxy primed. Well about 6 random pin holes got opened up from sand blasting. I could weld them shut but that would burn off the epoxy primer. I will also be hard to feather the edge of the epoxy because it doesn't sand very well. I am thinking of just using some JB weld to fix the pin holes. The holes are in the lower skirt below the bed so I could build it up from the backside. Any thoughts on how well this will work?
