John Turuk
fellas
I have started restoring a tractor. I'm doing this restoration in a double car garage. So far the dismantling and surface preparation are going well although I haven't touched the sheet metal and may not as I may leave that to a local body shop that has agreed to paint the tractor. Most of the process seems straight forward but in regards to the priming/painting/color selection process the more I read the more confused I get. As stated I plan on having the body shop spray all but the smallest pieces and I have decided to use Urethane. The body shop uses Dupont brand paint. So regarding these small pieces my plan is to buy a small container (say a quart?) of this urethane and get this poured into a number of small cans and brush paint and prime all of the very small pieces as I go. If this is doable do I need a respirator and what kind should I use? I believe that the hardener used with this type of paint is extremely toxic so I think for these small pieces I will forgo it. So I'd appreciate it if you will pick this process to pieces and offer suggestions or other ways to go about it.
Thanks kindly
John
Thanks kindly
John
