painting engine
Mike(NEOhio)
Location
Newbury, Ohio
I'm doing a rebuild and the block and head were hot-tanked and sprayed with a light oil after the machine work. I have some Variprime and a spray can of epoxy primer. What would be the best type of primer for the castings and sheet metal oil pan and valve cover?
If I don't use etching primer in valve covers the paint wants to lift. Grease free is critical too.I use SEM spray can etching primer.
