Blasting media for cast aluminum pedal tractor
I'm looking to "clean up" and paint my cast aluminum john
deere pedal tractor what blasting media do I use?
Also it's a model 520 pedal tractor which JD green is it?
Thanks in advance!
I use 80 grit glass beads on toys tractors.
A 520. You mean a 2 cylinder 520 or is that the casting number?
Any 2 cylinder should be classic green.
How about some paint remover and a good pressure washer ?
Don't use sand ! I did that once even with a lower powered than commercial blaster and still had it roughed up and had to do a lot of extra primering and sanding.
Most pedal tractors are sand cast. They have a rough texture anyway.
paint removers don't do a ting in cold weather besides the mess. You also have to keep reapply
the remover every thirty minutes or as it like to drip off.
I would rather use a sander and wire brushes in a drill or dremel tool over paint removers.
