RaulentRoi
New User
This message is a reply to an archived post by ih560 "Bondo Glazing and Spot Putty lifted primer".
I confirm a problematic experience with "Bondo Red Glaze Putty" pinhole and small cracks filler. I filled a couple of pinholes in my primer with this filler, let it cure for a couple of days, sanded over it to obtain a perfectly fine surface, primed over again and waited another 24 hours. That's a total of 72 hours cure time for the Bondo filler that requires only 3 hours. Result:
cracks in the paint everywhere the Bondo was applied over a surface 4 to 5 times the size of the applied area. It is a chemical reaction that has nothing to do with acids or cure time or what have you.
Stubborn as I am, I tried it again over a plastic bumper this time leaving plenty of cure time and double the amount of primer over the putty to isolate it from the base coat. I let it all dry as much as can be dried. Then, I passed the base coat of urethane Chrysler PB2 (metallic + pearl light blue).
Result: Cracks within 24 hours.
I join a link to my poof of purchase. You can find my product review there.
I had used this Bondo product with paint that was not urethane based for good results. Nevertheless, I find it annoying that such a poor quality product be sold by a big brand without the proper warnings written in big on the package. I call it commercial suicide.
I am now looking for a good putty that would do the job for a good result. [b:654c4848f0]Any suggestion?[/b:654c4848f0]
Paint PB2 that reacted to the Bondo
