case 1835c won't stay running
jingle28
New User
Starts right up but stalls quickly.
Does same thing over and over.
Fuel lines appear to be flowing good,
Pumps are working, fuel shut off is getting power,
Any ideas would be great
Loosten the two screw pump timing cover allowing fuel to leak out, if it runs without dieing then the injection pump needs repair. Governor flex ring is breaking up and bits like coffee grounds are plugging the return fitting. DO NOT knock the fitting ball out and keep running it or the retainer pins will shear off, seizing the dead assembly and breaking the drive shaft, get it serviced soon.
