So I've got an old Massey-Ferguson MF155 (it's an export model, as far as I can determine - kinda similar to an MF165 - Perkins AD4.203 engine)... it's been lying outside and quite heavily rusted for a few years, though it runs well when pull-started.
Want to sand-blast it and prime/repaint it.
The question is: how far would you recommend I should strip it, as a minimum?
Already taken bodywork (apart from side panels, which are proving tricky...) and fuel tank, as well as starter motor which needs replacing.
What else to take off - injectors? Injector pump? Water pump? Fuel pump? Should I spray the pipework / fuel lines separately, or when it's on, or not at all?
