Glennster or other bodymen
ASEguy
Location
Festus MO
I'm repairing 6 inch long 1/4 to 1/2 inch deep gouge in my wife's minivan. Some of the damage is on the sliding door. Is the SEM panel adhesive best for this or is it overkill? What would you use and how would you prep it? Thanks for your time.
its sounds like you have a tear in the metal. if you have acess to a mig welder, straighten the dent as best you can then mig weld the tear. if you dont have a mig and cant weld it, pull the inner door panel to access the backside, the use the semm and a piece of sheet metal as a backer. sand back the damaged area, apply filler and sand er out. then hit it with an epoxy primer over the worked area, then surfacer and block and prep. should be good to go.
