Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Removing overspray from a truck
soundguy
06-10-2014 16:56:21
what paint does your truck have and wht were you painting with.
in some cases a rg with naptha will take off light overspray.
in other cases ultra fine rubbing compound on a buff wheel can be used to polish her up
can't say much more without knowing what you sprayed and what it landed on.
Ryan_289
06-10-2014 18:55:41
 Re: Removing overspray from a truck in reply to soundguy, 06-10-2014 16:56:21
I was painting John Deere paint from a spray gun. The truck was quite a ways away. It is a stock 04 Chevy duramax.
soundguy
06-11-2014 06:42:10
 Re: Removing overspray from a truck in reply to Ryan_289, 06-10-2014 18:55:41
jd paint from a spray gun. lets see.. that narrows it down.. naw.. it don't.
alkyd?
urethane?
catalyzed?
if straight non catalyzed alkyd. id try some naptha on a cloth and do a wipe down.
Ryan_289
06-11-2014 06:53:21
 Re: Removing overspray from a truck in reply to soundguy, 06-11-2014 06:42:10
Sorry, im a newbie at body work. the can says that it is a synthetic enamel. Its the John Deere brand and I used John Deere thinner. Nothing else.
soundguy
06-11-2014 07:06:13
 Re: Removing overspray from a truck in reply to Ryan_289, 06-11-2014 06:53:21
synthetic alkyd enamil.
with no hardner, you may be in luck. soak a rag in naptha and give a wipe. could do the same with your reducer.. but check the reducer.. some have heptane and other goodies in it. i'd test those in an inconspicous spot to make sur ethey did not cloud the paint finish.
the fall back is ultra high polishing compound. low removal type. heck. many time simple car wax, buff on type will be enough.
avoid buffing or rubbing compounds.. only wax or polishing compounds.
Ryan_289
06-11-2014 10:24:25
 Re: Removing overspray from a truck in reply to soundguy, 06-11-2014 07:06:13
Will do, it looks like my thinnner has naptha in it. The truck is painted white, might be hard to tell if it clouds it.
[URL=http://s1132.photobucket.com/user/maldr427/media/20140611_122129.jpg.html][/URL]
soundguy
06-14-2014 17:14:09
 Re: Removing overspray from a truck in reply to Ryan_289, 06-11-2014 10:24:25
xylene is a pretty strong solvent. be carefull with that reducer...
