what regulator/filter to buy?
Nick m
Ended up buying a 60 gallon kobalt compressor that maxes out at 155psi. Keep in mind I'll only occasionally be using air tools and hoping to paint one tractor per year. Started looking around for regulators/filters and they are anywhere from $15-$500. What do you guys use?
stop at napa. they have a pretty decent in line air filter/ moisture trap and regulator set up. under a hundred dollars. if you are using an in line air tool oiler, mount it in a short whip hose to use just before it goes into the air tool. if you get oil in the main air hoses, you can never paint with them.
