recommended PPG Urethane paint..
bmagee
I do not have a lot of painting experience. I have painted a few Cubs, Cadets, etc. I am now restoring a Farmall F12 and thought of going bc/cc. I am reconsidering and maybe wanting to go a good urethane paint, with the shiniest or highest gloss hardener I can get.
Any recommendations?
Thanks in Advance
The hardener in urethane is a chemical that is needed to harden, a lot like mixing epoxy. You mix in the correct amount.
The gloss is obtained by putting on ENOUGH paint, it must be at the point of running be be correct.
I think urethane is a little less forgiving than acrylic enamel and would think about that if you do not have experience.
Thanks for reply - when you say less forgiving - give me an example if you don't mind?
the tractors I have painted I have used enamel and clear -coated.
if high gloss is what you are after, use a glamour clear vs a regular production clear. ppg has d8152 glamour clear. i use rm dc92 here at the shop, but we shoot diamont. here is a link to d8152
poke here
you can get good results with just about any paint line. preparation and a good spray gun work wonders.
here is an allis b in napa crossfire single stage urethane
<a href="http://photobucket.com/" target="_blank">
DCP02608.jpg" border="0" alt=" photo DCP02608.jpg"
</a>
farmall m in crossfire
DCP02454.jpg" border="0" alt=" photo DCP02454.jpg"
</a>
old vette in diamont base clear with dc 92 clear
DCP02223.jpg" border="0" alt=" photo DCP02223.jpg"
</a>
honda del sol in house of colors candy fusia with dc92
DCP02195.jpg" border="0" alt=" photo DCP02195.jpg"
</a>
and my farmall cub in tractor supply alkyd enamel, no hardener. its a working tractor and wasnt worth putting 1k in paint and materials on
tractorpics001.jpg" border="0" alt=" photo tractorpics001.jpg"
</a>
I have found that the urethane paint does not seem to cover as well if not put on thick enough. It is like you get a semi colored clear instead of a thin layer of color.
Glennster,
paint looks great! what should I use to final clean after I have wet-sanded primer, right before I shoot paint?
