Supplied air system
I've had one for 10 years, works fine. In the summer for long periods you might notice the warm air, not a problem for me.
I have one. Love it. Wish I had gone that route sooner. The blower is loud, but that's life. The air does warm up over time, but rather a warm breeze blowing on you than none at all.
i have a used air supply system wanting to sell. It is used for welding but i no longer own a welder.just need different colored lense to use for painting.
its always been inside shop. runs off 220 juice,Allegro industries unit. its probably not been used for 8 9 years since job change in shop. still looks like new and has really not much actual use since I had a battery powered fresh air weld helment prior to getting this unit. i take $850.00 for the complete setup. i think i gave close 2 grand for it originally. i used it when i had plasma cutter, welder etc.welder finally just gave out and i sold the plasma cutter. the headgear part is always stored in old fridge. its mounted on its own caster cart to moved around when using. includes several feet of supply hose and helment hose. where you at.
