DairyFarmerInMA
I have a tractor that was sandblasted then primed with rustoleum rusty metal primer then painted with central tractor paint about 12 years ago the top coat did stick well and flaked off but the primer stayed pretty well. I've power washed with hot water and removed most of the top coat done more disassembly than before and would like to 2 part epoxy some spots that I have yet to needle scale and wire brush.
Should I really remove the remaining primer?
Will the epoxy prime go over the rustoleum ok?
