Anonymous-0
I have a Case 2670 that has a sprung left door it shuts hard and i dont wanna break the handle by forcing it.
It looks straight from top to bottom but is out of alighnment on front door jam.
pinching the rubber on lower back bottom
of door.
Probably the same cab as the 90 series that I used to have. A close look will probably reveal that it got bent at the lower hinge. you would have to remove it and do some gentle persuading back. Start applying penetrating oil to the pins a few weeks before you plan to remove it.
