Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Serial Tag Refresh
RTR
11-21-2013 07:28:16
I would paint it (removed from tractor) a nice flat black or semi gloss black then take the tag and rub it painted side down across some fine grit sandpaper. Do it on a peice of glass so you know the surface is flat. Also be careful to only sand the raised lettering. It should sand the paint off and bring out the letters/numbers. Afterwards, apply a clearcoat to seal everything up. Install back on tractor and done.
Larry NEIL
11-25-2013 09:20:17
 Re: Serial Tag Refresh in reply to RTR, 11-21-2013 07:28:16
I have done the same a number of times with great results. On things like the old air cleaner bowls I just sprayed it all red on my Olivers and then used one of those fine rubber sanding blocks with some 320 grit wrapped around it and sanded VERY LIGHTLY!
RTR
11-25-2013 11:28:24
 Re: Serial Tag Refresh in reply to Larry NEIL, 11-25-2013 09:20:17
Please post which sanding block you used. I would like to try the same. Thanks
RTR
11-21-2013 07:36:12
Now, if you are worried about retaining the original print that isn't raised, It might be possible that someone could make you a decal to "refresh" the look of the tag. I know that Tim Talleur in NY makes them for the Farmall Cub and other Farmall tractors. I don't know how long they'll last but they sure do work nicely and put the finishing touch on.
See my Before and After Pictures from using one of his decals on a Farmall 140. If you didn't look close, noone would ever realize it was a decal.
This post was edited by RTR at 07:37:07 11/21/13.
