Yesterday's Tractor Co. Tractor Parts for All Brands
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Serial Tag Refresh
Steve@Advance
11-21-2013 06:49:31
108.245.66.82
Any proven methods of refreshing an aluminum serial number tag? The tag is in perfect condition except the black background is faded away. This is an embossed tag (TO35 Ferguson) with slightly raised, very tiny print. The actual serial number is raised higher than the rest of the background printing.
I saw the recommendation of a fine sharpie and clear coat, but I don't think I could ever get around all the tiny print... Any other suggestions? Thanks!
[Reply]   [No Email]
athol carr
11-21-2013 11:41:30
115.188.3.223
 Re: Serial Tag Refresh in reply to Steve@Advance, 11-21-2013 06:49:31
My son used a very fine draughtman's permanent marker pen to touch up the black. When finished looked just like the original. Then put two coats of clear enamel over the tag. Looks good. The tag was no perfectly flat so painting and sanding against a flat surface was not likely to work well.
[Reply]  [No Email]
RTR
11-21-2013 07:28:16
216.226.179.180
I would paint it (removed from tractor) a nice flat black or semi gloss black then take the tag and rub it painted side down across some fine grit sandpaper. Do it on a peice of glass so you know the surface is flat. Also be careful to only sand the raised lettering. It should sand the paint off and bring out the letters/numbers. Afterwards, apply a clearcoat to seal everything up. Install back on tractor and done.
[Reply]  [No Email]
Larry NEIL
11-25-2013 09:20:17
76.202.211.91
 Re: Serial Tag Refresh in reply to RTR, 11-21-2013 07:28:16
I have done the same a number of times with great results. On things like the old air cleaner bowls I just sprayed it all red on my Olivers and then used one of those fine rubber sanding blocks with some 320 grit wrapped around it and sanded VERY LIGHTLY!
[Reply]  [No Email]
RTR
11-25-2013 11:28:24
66.87.153.207
 Re: Serial Tag Refresh in reply to Larry NEIL, 11-25-2013 09:20:17
Please post which sanding block you used. I would like to try the same. Thanks
[Reply]  [No Email]
RTR
11-21-2013 07:36:12
216.226.179.180
Now, if you are worried about retaining the original print that isn't raised, It might be possible that someone could make you a decal to "refresh" the look of the tag. I know that Tim Talleur in NY makes them for the Farmall Cub and other Farmall tractors. I don't know how long they'll last but they sure do work nicely and put the finishing touch on.
See my Before and After Pictures from using one of his decals on a Farmall 140. If you didn't look close, noone would ever realize it was a decal.
This post was edited by RTR at 07:37:07 11/21/13.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
