TractorLinks.com
Re: Paint Finish Textured - What Happened? Need some Help
RTR
09-29-2013 09:02:01
what are you meaning by improper gun. I kind of feel that is/was the problem too. I am using the common Harbor Freight HVLP gun that 90% of the people on the board use. They're known to do an "above average" job for what they are, and I've gotten better results with it before.
I feel like I don't have it adjusted properly, and really don't know how to adjust it properly. Reading the internet how to do it and actually having someone there to help show you how are 2 very different things. I've tried reading articles on adjusting and it seems like it makes it worse than if I just "winged it" on the adjustment.
I also agree it was a combo on the gun and the chemical reaction of the mixed paint with the weather. Is that what you meant by "Improper Gun" ?
CNKS
09-29-2013 09:34:33
 Re: Paint Finish Textured - What Happened? Need some Help in reply to RTR, 09-29-2013 09:02:01
Your gun is set when the air is set to the spec on the gun (use the gauge on the gun, not on the wall) or in the instructions that came with the gun, and the fluid wide open. Set it that way, leave it that way. I never change the adjustments in my gun. If the pattern is to big I use a smaller gun. A major advantage of HVLP is that you set them and forget them.
CNKS
09-29-2013 11:14:54
 Re: Paint Finish Textured - What Happened? Need some Help in reply to CNKS, 09-29-2013 09:34:33
"and the fluid wide open." should read pattern and fluid wide open. I realize that some will disagree with that statement, but I have success using a touch up gun for small items rather than repeatedly adjusting the large gun to fit the smaller parts. In fact I use the touch up gun 95% of the time. The large one is used only on the chassis and the sheet metal if needed. I don't use the cheap guns as I would rather pay the expense for a good one, use it for years and buy repair parts as needed. I have not used 2150 or any other alkyd enamel. Directions for quality paint are very specific, with the PPG I use, the mixture is given exact and does not need to be messed with. The only thing that needs to be changed is the reducer, which in PPG Omni is 3 ranges. I never change the amount. I would rather paint than mess with guns and mixtures.
