TractorLinks.com
Re: Paint Finish Textured - What Happened? Need some Help
Jason S.
09-24-2013 11:23:08
I would advise against using All You Need. It is nothing but spray able body filler. It is not moisture proof and it's way too hard to sand. I've used it many times along with the yellow Z Chrome primer...both are made by Clausen. A good epoxy will provide moisture resistance, adhere better,and flow out smoother. All you need leaves a textured finish and it's hard too sand out. I usually knocked it down with 180 and then water sand with 400. I have seen it crack after a year or two also, and once I got bad hardener with mine and it wouldn't set up and I had to scrape it off. Another thought for you is if you painted that stuff outside and the gray All You Need ive used looks almost black, I would say the panels were heated up before you sprayed them to where the paint flashed as soon as it hit the panel and didn't flow out. Using medium reducer didn't help that any either.
