TractorLinks.com
Re: Paint Finish Textured - What Happened? Need some Help
Rod (NH)
09-24-2013 07:26:10
Looks like severe Orange Peel to me.
RTR
09-24-2013 08:31:41
 Re: Paint Finish Textured - What Happened? Need some Help in reply to Rod (NH), 09-24-2013 07:26:10
Rod (NH) said: (quoted from post at 19:26:10 09/24/13) Looks like severe <a href="http://pc.dupont.com/dpc/en/US/html/visitor/s/trouble/PDSG_OrangePeel.html">Orange Peel</a> to me.
I thought orange peel, but it seems much worse and maybe different than that. I was conscious about the way I held my gun and conscious about not putting a heavy coat on each time. I did put about 3-4 coats of paint on everything and waited 15-20 minutes in between coats. Maybe a little longer.
Before, when painting (and it turned out better) I wasn't as conscious about keeping 90 degree angle, I put it on thick first time around, etc.
I've found this article about troubleshooting painting problems.....my problem seems to fit a couple of the situations, but my problem seems worse than those.
http://www.streetrodderweb.com/tech/0901sr_help_with_troubleshooting_paint_problems/viewall.html
This post was edited by RTR at 08:32:18 09/24/13.
RTR
09-24-2013 08:27:23
Yeah, well I've never had it happen and I haven't done anything any different except do more to make the finish better.
I'm thinking about scrapping that regulator and water filter on the gun because I've not liked the way it operated since I bought it. It seems like it is only either OFF or ON. You can turn the knob while holding trigger and it will go from 0 psi to 35 psi to about 40 psi. That is it. It's funny this started happening after I started using that set up.
Rod (NH)
09-24-2013 11:00:40
 Re: Paint Finish Textured - What Happened? Need some Help in reply to RTR, 09-24-2013 08:27:23
Lose the regulator at the gun altogether (you don't need it) but keep the gage.
