Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Paint Finish Textured - What Happened? Need some Help
B-maniac
09-23-2013 18:02:27
Unless you are using a good heavy primer/surfacer and applying a good 3 -4 coats over the sandblasted parts and then wet sanding down smooth,taking off two coats, then it's possible that you are not filling in the rough sand blast profile and it will affect the final gloss. They may be using too coarse of an abrasive or too much air pressure or both. You said you were wet sanding but how much? After you apply last coat of primer, apply a tracer coat or use the powdered tracer or "guide coat" of contrasting color so when you wet sand you just go until the tracer coat color is all gone to ensure smooth final finish. You need no coarser than 400-500 for your final sanding. 800 is too fine for proper bite.Also you said you were "having the blasted metal primed" What are they using and how much? I think between the blasting profile and the product they are using is where you will find your problem. RB
