TractorLinks.com
Re: Engine Paint Possible Issue?
Rod (NH)
09-23-2013 11:00:29
My opinion: If you are having trouble getting it started after a rebuild, you have more important issues to work out than the paint. In any event, you can expect the paint to burn off the exhaust manifold and the cylinder cooling fins in the area(s) where the exhaust manifold connects. The paint on the head and the head cooling fins is questionable in my experience. The two-cylinder air-cooled Wisconsin engine I painted in the past with automotive paint had an aluminum head so I didn't paint that part at all.
Scott Rollins
09-23-2013 12:55:49
 Re: Engine Paint Possible Issue? in reply to Rod (NH), 09-23-2013 11:00:29
Yeah I'm actually on another forum sorting out the other issues and I'm pretty close to resolving the engine issues and paint is next before I drop it back in, just thought I would look ahead a little.
Rod (NH)
09-23-2013 13:56:44
 Re: Engine Paint Possible Issue? in reply to Scott Rollins, 09-23-2013 12:55:49
I wouldn't worry too much about the paint. It's not going to do any harm and won't make any kind of mess. Burning off in the areas I mentioned is considered common. That would also happen with any paint applied on a new engine direct from the factory. They wouldn't be using any special high temp paint. As far as the heads are concerned, they're going to be mostly covered by air shrouds anyway, along with the cyls, aren't they? At least they are on my 4 cyl Wisconsin VE4D. I wouldn't try and apply any paint over the existing - that could make a mess with wrinkling of the film, especially if it's a lacquer over enamel. A proper re-paint would involve completely stripping the existing paint.
Good luck in getting it running properly. Is that a hydraulic pump it's driving? Does it go in a skid-steer?
Scott Rollins
09-24-2013 05:04:39
 Re: Engine Paint Possible Issue? in reply to Rod (NH), 09-23-2013 13:56:44
Yeah it drives 2 hydraulic pumps, goes in a 73 International Skid Loader 3200 B
