Just finished a ton of sheet metal work for a friends 801 Ford. Sand blasted, welded, bondo, primer, glazing finally got pitting and damage eliminated.
He only asked for CNH base color on the parts. Can I wet sand and buff the base color or should I clear coat? If so, how long do I let the paint cure before clear coating? Used hardener and reducer in the base color.
Color went on very nicely. Minimal dust specs and orange peel. I do not expect wet sanding to take too long.
