Painting IH 560
slifnom
I get the IH Red 2150, but the cream(I don t think it is white?)is 901 then correct? I was reading the article on the 350u and assuming the paint colors would be the same! Are they?Thanks in advance I was going to use a primer from Fleet Farm Am I missing anything here? Please advise
901 is correct on both tractors. Don't use cheap primer, use epoxy primer. However the epoxy will cost you more than the 2150 topcoat. You can get PPG/Dupont urethane by crossing IH 2150 to 71310/96766. If you don't want to use epoxy at least get the primer for IH 2150 from the CaseIH dealer.
