TractorLinks.com
Re: First Time Electrolysis Setup
charlespretzer Ks.
07-23-2013 15:46:14
Looks good . I didn't have much luck on cast.Stripper & a pressure washer works better on cast.
bigbore
07-24-2013 09:12:03
 Re: First Time Electrolysis Setup in reply to charlespretzer Ks., 07-23-2013 15:46:14
molasses rust removal works great on cast,it's cheap ,easy,and safer.
charlespretzer
07-24-2013 11:23:39
 Re: First Time Electrolysis Setup in reply to bigbore, 07-24-2013 09:12:03
What's molasses rust removal???
JoeM(GA)
07-24-2013 18:51:00
 Re: First Time Electrolysis Setup in reply to charlespretzer, 07-24-2013 11:23:39
It does work, we're talking feed grade molasses, not what you might pour on your pancakes!.
I did it one time, it does work, but the leftover liquids stunk to high heavens! Had to dump it out way down in the woods, ground smelled for quite a while, at least with my electrolysis I can pour the iron rich water out on my grass until I get close to the bottom of my container, then I pour whats left in the bottom (paint, grease and such) out ina small pail and let it dry out and then put it in the trash
bigbore
07-25-2013 07:15:57
 Re: First Time Electrolysis Setup in reply to JoeM(GA), 07-24-2013 18:51:00
I have my molasses mix out side in a small shed,well ventilated ,and unless you open it ,you can't smell the fermented molasses.You should have poured it around you trees ,the smell goes away quickly,and is good for them!Just my opinion!I use it regularly with great results!
bigbore
07-25-2013 11:28:24
 Re: First Time Electrolysis Setup in reply to bigbore, 07-25-2013 07:15:57
http://www.collectorsweekly.com/stories/95166-cwrust-removal-tip-look?in=user
Here's a link to my How-to and some small items I cleaned to show how it worked.
