Repaint Question
A year or so ago I painted a part with PPG acrylic urethane paint. Now I find that I painted it the wrong color. My question is when I repaint can I simply paint over the wrong color with the correct color, or should I scuff or sand the part before painting? Or, should I beadplast the part and start from scratch with primer and paint? Thank you for your input.
Sand with 400 and repaint. If you should get to bare metal use epoxy primer on that area, probably simpler over the whole part and repaint.
I repainted my tiller and tractor. Sanding & cleaning was the hardest part. Hal
