TractorLinks.com
Re: Problems with paint gun
El Toro
06-10-2013 03:56:42
Read the manual that came with your spray gun. It should tell you what your pressure at your regulator should be. On my gun its 35psi. If you buy paint from PPG, Martin Senour or Dupont it will tell you on the paint can how much thinner to use. Hal
Evan Mellott from Iowa
06-10-2013 08:05:15
 Re: Problems with paint gun in reply to El Toro, 06-10-2013 03:56:42
This gun says 20 psi max.
The Dupont tech sheet states that HVLP should be at 8-12 PSI. I know the paint was mixed correctly 8:1:2, and I had to add some more thinner because the paint was just to thick.
Rod (NH)
06-11-2013 12:05:29
 Re: Problems with paint gun in reply to Evan Mellott from Iowa, 06-10-2013 08:05:15
Adjust your pressure as explained here
CNKS
06-10-2013 14:54:41
Set it to what the gun says, the max figure is the one to use, it does not vary with the type of paint -- the pressure is reduced to about 10 psi inside the gun.
