Yesterday's Tractor Co.
Shop Now View Cart
Re: lead paint
06-03-2013 17:25:28
It hasn't made any difference in PPG products as far as I can tell. I think the colors are a little different, but the dealer can change the toners to suit. PPG MTK acrylic urethane still lists lead in some colors. I imagine DuPont and NAPA are the same unless you mean really cheap paint.
06-05-2013 12:07:10
 Re: lead paint in reply to CNKS, 06-03-2013 17:25:28
It has made a big diffrence in durability on the cheaper paints ,Red espacilly
06-05-2013 14:39:13
 Re: lead paint in reply to tommyw-5088, 06-05-2013 12:07:10
Could be, I don't use cheap paint, even with lead in it doesn't last long. When alkyd enamel/acrylic lacquer were used on factory painted cars they faded badly in a couple of years. Could be retained with wax but it eventually gave up. Modern paint is immeasurably better, lead or not. I don't worry about lead or iso's because I use the proper protection. That said the acrylic modified alkyd enamel paints sold by tractor dealers aren't that bad.
This post was edited by CNKS at 14:39:49 06/05/13.
06-05-2013 12:08:55
If proctetive gear is work ,spraying lead paint is no more dangerous than anything esle .
Actually its likley safer than the high Iso. loads of some polyurethanes .
06-05-2013 13:31:28
 Re: lead paint in reply to tommyw-5088, 06-05-2013 12:08:55
unfortunately, lead is very toxic. it stays in the environment for a long time. sanding it generates an inhalation hazard, as well as the atomized paint when applying. when the vehicle is ultimately scrapped and melted down, the lead is released again. typical consumer use does generate quite a bit of toxic waste. the spray booth here at my shop runs 98% efficiency filters to trap voc emissions. we dispose of all waste products thru an epa licenced waste hauler. current cost is about 700 dollars for a 55 gallon drum. if you using the proper safety gear, it is a lot safer. how many home painters are wearing supplied air, paint suit, nitrile gloves ect and disposing of the generated waste correctly. the products are nasty.
