Anyone used the Non ISO 2K top coat paints?
Chase_99
With the often questions on here regarding what paint JD vs automotive type to use on farm machinery I've wondered if anyone has used the 2K iso free top coats that are out. They may have no ISO's but who knows what else in there instead. Below is a link to a spec sheet on one. Looks like most paint manufactures make them now for different applications.
Untitled URL Link
First red flag is the dry times and dust free times. That's a lot of time for foriegn objects to find the wet surface. Being it's an industrial epoxy and that is it's main intended use , I doubt dirt is much of an issue like it would be on your tractor/car hood. Any limitations on color choices? May be a better mouse trap or may be a new company dreaming.
I don't think it's a new company dreaming. PPG's NCT clearcoat was available in 1995 and it is isocyanate free. I used it back then and it was a good clear.
I tried it too..once. Could only use it on single panel painting because dried too fast. Good for inside door jambs etc. I don't like iso,s either but refuse to be the guinnea pig for a company grasping at straws either. When there is a break-through , all the majors will have it.
