Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 1942 JD Painting
Chase_99
05-28-2013 23:01:59
So are you getting the machine sand blasted? As mentioned depends on how much you want to spend, equipment, and experience. If this is your first crack at painting I'd say go with the paint from you're local JD dealer.
Brandon Kram
05-29-2013 22:39:43
 Re: 1942 JD Painting in reply to Chase_99, 05-28-2013 23:01:59
Yes I want to sandblast the whole tractor. I have started sand blasting smaller parts. I have not painted a tractor before but have sprayed other things. Just want a durable paint, but sounds like the JD classic green is going to be fine with harder.
CNKS
05-30-2013 18:11:18
 Re: 1942 JD Painting in reply to Brandon Kram, 05-29-2013 22:39:43
Hardener does not make the paint last longer. It makes it cure faster, thus it is easier to repair and may give a little more gloss, that is all. UV protection, if any, is in the paint. not the hardener.
Patsdeere
05-29-2013 23:26:50
Whatever you do, don't sandblast anything that can't be taken off the frame. (IE don't blast the frame). I don't care how well you duct tape off and seal things, the sand will still find a way in to places where you don't want it. Seen it done. Best to simply wire wheel/strip the frame and sandblast all the pieces.
