Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 1942 JD Painting
Patsdeere
05-27-2013 22:46:36
All depends on how much $ you want to spend and the equipment you have (fresh air supplied breathing or not). If you look through the forum you will see there are as many opinions as there are people. However, the consensus is to use epoxy primer and then a good quality paint. Some require hardeners (need supplied air system to breathe) others don't. Also a talk with the local supplier would be good. They will be able to give you an idea on costs and options in your area.
Brandon Kram
05-28-2013 21:49:02
 Re: 1942 JD Painting in reply to Patsdeere, 05-27-2013 22:46:36
Patsdeere, Thank you for all the input.
Meangreen
05-30-2013 05:53:40
 Re: 1942 JD Painting in reply to Brandon Kram, 05-28-2013 21:49:02
I recently took my Allis WD45 down to the frame, left the engine and rear end together and then soda blasted it. Worked out pretty nice.
