Yesterday's Tractor Co.
Shop Now View Cart
Re: PPG Primer, catalyst and associated questions
04-27-2013 13:26:00
Epoxy has to have the catalyst or it won't work. it is ideal for sheet metal, cast or whatever. It is NOT sandable. On sheet metal it will give a good enough finish when top coated. For best results use a sandable surfacer over the epoxy. On relatively smooth surfaces such as battery boxes, generators, starters etc, or anything that is not the hood, gas tank, grill, etc, epoxy is fine when topcoated. A sandable primer, high build or otherwise does not adhere as good to the bare metal as epoxy. It is the only true primer that I use.
Luke R
04-27-2013 19:26:17
 Re: PPG Primer, catalyst and associated questions in reply to CNKS, 04-27-2013 13:26:00
Can you spray multiple coats? If so, what are the correct steps to ensure it looks good? Again, thanks to everyone.
