Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: PPG Primer, catalyst and associated questions
Luke R
04-26-2013 08:22:04
You mentioned hardener. Should I put hardener in with the epoxy? We have the omni version. Also, I was wondering if it is sandable at all after applying? It sounds like it is set as soon as you spray for paint. Probably wouldn"t be good to use with the sheetmetal then? Thanks for the advice
CNKS
04-27-2013 13:26:00
 Re: PPG Primer, catalyst and associated questions in reply to Luke R, 04-26-2013 08:22:04
Epoxy has to have the catalyst or it won't work. it is ideal for sheet metal, cast or whatever. It is NOT sandable. On sheet metal it will give a good enough finish when top coated. For best results use a sandable surfacer over the epoxy. On relatively smooth surfaces such as battery boxes, generators, starters etc, or anything that is not the hood, gas tank, grill, etc, epoxy is fine when topcoated. A sandable primer, high build or otherwise does not adhere as good to the bare metal as epoxy. It is the only true primer that I use.
Luke R
04-27-2013 19:26:17
 Re: PPG Primer, catalyst and associated questions in reply to CNKS, 04-27-2013 13:26:00
Can you spray multiple coats? If so, what are the correct steps to ensure it looks good? Again, thanks to everyone.
