Yesterday's Tractor Co.
Shop Now View Cart
Re: Visible gas pump-Clear coating brass and a primer question
Evan Mellott from Iowa
04-22-2013 06:41:52
I was told Etching primer is supposed to be used on bare metal, and that's what the sheet metal is right now.
04-22-2013 08:40:50
 Re: Visible gas pump-Clear coating brass and a primer question in reply to Evan Mellott from Iowa, 04-22-2013 06:41:52
What he meant was etching primer is only needed on smooth , right out of the stamp or roller type steel that is so smooth that primer won't adhere properly unless sanded or acid etch primer is used. Your bare steel is or will be allready sanded or sand blasted to provide the bite for epoxy primer. If you have allready bought etch then use it. Just wasn't needed. As long as this isn't going to be outside in all the sun n rain and extreme temps then I really don't thing you will have a problem with the economy clear cote. Are there better products for this use? Yes there are . How much do you want to spend and will you ever see the net gain in durability? What's the intended use? Only you can answer that.
04-22-2013 08:45:57
 Re: Visible gas pump-Clear coating brass and a primer question in reply to B-maniac, 04-22-2013 08:40:50
Thanks, that pretty much answered my questions.
