TractorLinks.com
Re: Visible gas pump-Clear coating brass and a primer question
Stephen Newell
04-22-2013 04:19:16
The variprime primer will work well for the aluminum. You should wash the aluminum down with lacquer thinner prior to painting though. Aluminum secretes an oil. It's what turns your hands black handling an aluminum ladder a lot. The Crystal Clear Enamel won't hold up very long on brass. It would be better to use a product especially formulated for brass such as Nickolas #8321 Exterior Lacquer. http://www.finish1.com/page_products_8321.htm
Evan Mellott from Iowa
04-22-2013 06:45:01
 Re: Visible gas pump-Clear coating brass and a primer question in reply to Stephen Newell, 04-22-2013 04:19:16
I want to clear-coat everything in the first picture with the aerosol can of clearcoat, including the aluminum numbers.
Stephen Newell
04-23-2013 05:01:06
 Re: Visible gas pump-Clear coating brass and a primer question in reply to Evan Mellott from Iowa, 04-22-2013 06:45:01
The brass-lac will work on aluminum too. Because of the nature of the metal the finish won't be as durable as it is on brass. I normally just buff aluminum and don't clear coat it. Aluminum will normally shine up like chrome.
