TractorLinks.com
Re: high build primer
B-maniac
04-01-2013 17:31:19
Yes, use the epoxy first then hi build 2 component urethane primer surfacer then block snd smooth. I wouldn't try to bridge the parting seam as it will ultimately crack in time from expansion/contraction and /or flexing plus would lower retail value if that will ever be a factor.
kylemorley
04-05-2013 17:25:29
 Re: high build primer in reply to B-maniac, 04-01-2013 17:31:19
In aircraft usage (and high end motorcycle restoration) the bare metal is usually etched with a acid treatment like Alumnaprep33, then a conversion coating like Alodine.
This leaves a corrosion resistant coating the is ready for whatever paint you please.
Painting aluminum is always tricky because the bare aluminum developes an oxide coating almost immediately, that isn't a good base for paint. A conversion coating like Alodine leaves a microscopic layer of chromate, chemically similar to anodizing, which is.
showcrop
04-05-2013 19:45:22
 Re: high build primer in reply to kylemorley, 04-05-2013 17:25:29
The oxide will come off on your fingers black and will feel almost oily.
