Scuff & Puff Glennster?
neblinc
I have this 2424 that I want to paint red with the Valspar Restoration Series paint that I picked up cheap at TSC when they were closing it out.
What would I use for a primer to "fill" in the chips in the yellow paint? Or do I just prime and paint and call it good. Anything would look better than what it is now :lol:
Randy
randy, for a quick down and dirty, scrub the whole works with comet cleanser and a red scotchbrite pad, and hose it down with wax and grease remover. get some evercoat feather fill, lay 2 to 3 heavy coats with a big bore spray gun. (have a gallon of acetone handy if the featherfill starts setting up in the gun). then d/a sand it down with some 180, then 320 and shoot it. the feather fill is a 2 part polyester surfacer. its about like a fiberglass resin primer. you can just featherfill prime over any real bad areas that you want to smooth down. when filling chips, it fills quick, then you need to sand down some of the featherfill till its level with the paint around the chips.
Rolling along, starting to pick up a little more now. Was off a
while in january, had a chest grabber, doin better now tho.
D/A with a 36 grit pad, clean-up with a 80 grit pad. Clean bare metal and use a high build rust protectant primer, scotch bright area and shazaam..... PAINT AWAY!!!!
SORRY, first clean with spiral twisted wire wheel, then apply aircraft paint stripper,remove using same wire wheel then do the other. goes pretty quick after the stripper does its job. Coat area with brush let stand five min then coat a second time let stand five to ten and the wire wheel takes it right down. wear protective clothing and rubber gloves, dont forget to protect those EYES!!!!!
I have used stripper before and did not care for it, way to messy.
I will go with Glennster's suggestion.
Randy
