| Antique Tractor Paint and Bodywork |
Topic: HVLP Conversion
[Return to Forum]
| Author |
[Modern View]
| BobV
02-13-2013 05:30:37
108.94.106.116
I understand, High Volume Low Pressure,I have a compressor that can produce 125 lb psi all day long, how will I regulate the air,larger hose for the volume?. What does it take to get this done? Thanks in advance to any and suggestions. |
[Reply] [No Email] | |
| CNKS
02-14-2013 18:41:55
216.144.104.128
Re: HVLP Conversion in reply to BobV, 02-13-2013 05:30:37
| Your compressor has to hold the psi at whatever your gun requires. It does that by CFM (cu ft/min). Even small compressors will give 125 psi, just not for long. I have two compressors. The one I use for painting is a single stage and puts out 17 cfm at 90 psi. Will work with any spray gun on the market, borderline with impact tools etc. The other is a 2 stage, puts out 24 CFM at 150 psi, ok for impact tools, sanders, etc, but is very marginal for sand blasting. The pipes attached to my compressors are 3/4" diameter with 1/2 inch drops. The regulator and water trap on the wall is 100+ pipe feet from the compressor, followed by a 3/8 inch hose attached and water trap bulb and gauge on the gun. Use the regulator on the wall to feed the gauge on the gun to account for any pressure drop in the hose. |
| El Toro
02-14-2013 06:47:48
108.3.143.30
| The HVLP spray guns consume a lot of air. You may have a problem spraying a large item. Hal |
| glennster
02-13-2013 06:10:21
75.57.119.90
| you can run standard 3/8 inch air lines for a typical hvlp automotive style gun. use an in line filter and moisture trap at the supply end of your air hose. then run a gun regulator right at the spray gun. your manual that came with your spray gun should have the cfm it requires. be sure your air line has never had a line oiler on it. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
