Yesterday's Tractor Co.
Shop Now View Cart
Re: Sand blaster help ?
02-06-2013 08:41:11
Basicly all the small blaster are the same, most are of the deadman type. problem with them is that the tip wear out easy, as does the shutoff bar.
Next better unit uses a gate valve that has a 1/4 turn action, problem with this type is they use a Stainless Steel ball and plastic or brass housing. Needless to say the soft plastic or brass gives way under use over time.
The best uses an air operated shut off valve located in toward the tank controled with foot pedal or by hand. Tip threaded to hose. Big $$$$.
Each unit goes up in price but the longer the tip/valve will last. That said the style you speak of in your last paragraph...Deadman type. It comes in a cheap sytle and a more expensive type, difference being a better grade of material used.
Hope this helps and also check out all the YouTube videos on sandblassting.
02-06-2013 09:27:34
 Re: Sand blaster help ? in reply to BobinMi., 02-06-2013 08:41:11
yeah i think i have the 1/4th turn valve one because it does have a steel ball for a shut off im thinking i need like 3/32 nozzles like that type of nozzles when i got the thing it came with like 4 or 5 nozzles and i cant remember what sizes they were... I think thats what that other one is called it kinda sounds like it the deadman type. The main type of material i use is just regular nebraska sand hills sand might be a little bit course but it works great and i got a great supply of it east of my house bout 2 or 3 miles. i just wanted an idea on if those deadman type would be a good type to get because it seems like people around here in NEb carries something simular to the deadman tips.
