New Divilbiss guns
I see they have guns without rigid cups. Seems like they work somewhat like a baby bottle with a disposable plastic liner to allow for easier cleanup. I hate cleaning mine up. Any thoughts on them? I think they're called DeKUPs.
Thanks,
Wes
Havn't seen it but it won't help much. The inside is the work, the cup is simple.
Wes, They work fantastic, but are more in the line for production shops where large amounts of materials are sprayed every day. The price of liners virsus material for clean up.
The cup is easy to clean. You need to completely disassemble the spray gun to clean it thoroughly. I use to clean my same make gun and suspend it in lacquer thinner after cleaning
and let it soak. I used a piece of wire on the gun parts sticking above the thinner. Hal
The disposable liner set up from 3M is awesome. It makes clean up easy but it also allows you to spray with your gun turned upside down!
