How to remove rubber scuff marks from painted metal???
Ralph Bauer
Busted a tubeless rear tire on my green 5010 in road gear .... some chunks caused lots of black scuffing on the (dull) green paint in and outside the right wheel well before I got her stopped and pulled off the road. Any good ideas on how to remove them without doing damage to the paint?
Thanks in advance for all your input. Ralph in Oklahoma.
Go to your parts store and some Dupont
First KLean. Wipe it on with a clean cloth.
Take a dry cloth and wipe it off before it flashes.
Works good to use on a large area before you
buff/polish/wax. Stuff is not cheap. It is what the pros use.
SOS pads, lots of water and rub lightly. Works good on race car paint, no scratches as long as you don't apply too much pressure.
(quoted from post at 23:37:05 01/16/13) SOS pads, lots of water and rub lightly. Works good on race car paint, no scratches as long as you don't apply too much pressure.
If you use the clay bar, you can apply lots of pressure and you don't have to worry about scratching the paint.
