Yesterday's Tractor Co.
Shop Now View Cart
Re: Omni acid etch proper use/prep before hand
12-14-2012 10:03:20
Forget MP176, it is not a rust preventer or a rust converter, it is designed for body shops who use new metal and do not wish to sand. You will be sanding or wire wheeling everything (at least you should be), making 176 redundant. Just use MP170/1/2. Do NOT use 176on cast as there is a possiblility that it will lift the paint. If I am not able to remove the rust mechanically I will use Picklex 20 or Must For Rust which do not need to be washed off, they can be scuffed and have a wax and grease remover applied. I do not use anything containing acid on cast for fear it will lift the paint, as it can be trapped in the pores. If I remember right, Showcrops problems were not caused by him, but by a so called professional who hurried the job, did not remove the rust and caused problems. I am not incuding the B maniac and Glennster in that category as you can believe 99.9% of what they say (no one is perfect).
