TractorLinks.com
Re: Blasting Equipment - Why isn't this Ever Used???
RTR
12-06-2012 15:07:41
Since it would be a way of cleaning, I guess that would be a good point. Otherwise, if it were simply sandblasting, I would not use it on the tractor for that reason, but with the water I would to clean the tractor. I wonder if the possiblity would be high rather than using a steam cleaner to wash one down like I do now?? Shouldn't draining the fluids and changing them take care of any water that would happen to get in somewhere?
GlenIdaho
12-06-2012 16:38:50
 Re: Blasting Equipment - Why isn't this Ever Used??? in reply to RTR, 12-06-2012 15:07:41
If I have understood you correctly, draining the fluids would remove the water, but if a blasting media such as sand is used, I don't think merely draining the fluids would remove the grit left behind. As with dry blasting it is the general rule that if you are going to blast areas where sand can enter the internal parts of the motor, trans etc you must take very special care to seal any possible entry point. I understand that many guys have sandblasted the entire tractor, but I would be reluctant to do so.
